Overview
EdgeMind-Manager Overview
EdgeMind Manager is a one-stop industrial IoT solution dedicated to addressing remote device management, device monitoring and operation & maintenance, as well as industrial data collection and visualization. The
management interface is web-based, offering a simple, convenient, and feature-rich experience that is easy to
integrate. It effectively enhances the management and maintenance efficiency of edge devices in industrial
environments, significantly reducing operational costs.
EdgeMind Manager Deployment Guide
Supported Environments
Deployable to:
- On-premise Linux servers
- Local virtual machines (VMs)
- Cloud VMs (Alibaba Cloud, Microsoft Azure, AWS, etc.)
1. System Requirements
Minimum Specifications:
- CPU: 2 vCPU cores
- Memory: 4GB RAM
- Storage: 32GB SSD
- OS: Ubuntu 18.04 or newer
Other Linux distributions also can be supported
2. Network Configuration
Required Open Ports:
Port | Protocol | Service |
8080 | HTTP | Web Interface |
8082 | HTTP | Message and ithing |
30001 | HTTP | For OTA |
9000 | HTTP | For OTA |
1883 | TCP | MQTT Broker |
5500 | TCP | VNC Server |
9191 | Websocket | VNC |
8024,50500-50510 | TCP | Terminal |
3. Installation Procedure
3.1 Install Prerequisites
# Update system packages
sudo apt update && sudo apt upgrade
# Install Git
sudo apt install git
# Install Docker (official script)
curl -fsSL https://get.docker.com | sudo sh
# Install Docker-Compose
sudo apt install docker-compose
# Verify installations
docker --version
docker-compose version
3.2 Deploy EdgeMind-Manager
git clone https://github.com/Advantech-EdgeSync-Containers/EdgeMind-Manager.git
cd EdgeMind-Manager
chmod +x start.sh
# Execute installation (may take 10-20 minutes)
./start.sh
Note: The script will: Pull Docker images Configure container networks Initialize database schemas
4. Accessing EdgeMind-Manager
After successful installation, access the web interface:
http://<SERVER_IP>:8080
You will see the login page with following default credentials:
Default Account:
- Username:
admin
- Password:
admin
