Overview
Container Overview
After the container is launched, it will start the EdgeMind Studio application based on the NVIDIA Jetson or HUAWEI Atlas platform, providing the following core functionalities:
1. Video Management Features
Multi-source Video Management: Supports local cameras, IP network cameras, and uploaded MP4 video files.
NVR (Network Video Recorder): Records and enables playback of connected camera feeds.
2. Video AI Analysis & Performance Monitoring
Model Management: Provides AI model deployment and management for flexible and convenient scalability.
AI Intelligent Analysis: Real-time object detection based on the YOLO model for camera feeds or MP4 videos, with alert notification support.
Video AI Region Detection (ROI Analysis): Allows defining key detection regions (ROI) in the video frame, focusing AI analysis only on specified areas to reduce computational load.
Performance Monitoring: Displays real-time AI processing metrics, including video frame rate, model failure rate, and CPU/GPU resource usage.
Multi-screen Live Viewing: Supports simultaneous display of multiple video streams for real-time monitoring.
Container Demo
Requirements
Hardware
NVIDIA Jetson platform
Verified Device: MIC-332/ITA-560
Verified Device: MIC-ATL2S
Software
- Docker (version 20.10 or higher)
- Docker Compose (version 1.29 or higher)
Container Quick Start
We offer two ways to launch EdgeMind Studio: Docker-Compose and script-based startup. You can use either method as preferred.
Step 1: Download the launch scripts and docker-compose.yaml file
git clone https://github.com/Advantech-EdgeSync-Containers/EdgeMind-Studio.git
Step 2: Start EdgeMind Studio container
For NVIDIA Jetston Platform
If you want to start using Docker Compose
cd EdgeMind-Studio
docker-compose -f docker-compose-jetson.yml up -d
Or if you prefer to launch via a run script
cd EdgeMind-Studio
chmod 777 run_edgemindstudio_jetson.sh
./run_edgemindstudio_jetson.sh
For HUAWEI Atlas Platform
cd EdgeMind-Studio
docker-compose -f docker-compose-atlas310b.yml up -d
cd EdgeMind-Studio
chmod 777 run_edgemindstudio_atlas310b.sh
./run_edgemindstudio_atlas310b.sh
How to use?
Once the setup is complete, you can access EdgeMind-Studio through a web browser at http://$ip:8080, where $ip refers to the device’s actual IP address.
