Overview
This container image, Deepseek-R1 1.5B Ollama on NVIDIA Jetson™, bundles a ready-to-use Ollama inference engine with the DeepSeek R1 1.5B model and the OpenWebUI interface for LLM interaction.
Developed for NVIDIA Jetson™, this image offers:
- On-device LLM (DeepSeek R1 1.5B via Ollama) inference (no internet required post-setup)
- Open-AI compatible APIs
- Streaming chat support via OpenWebUI & Ollama
- Modelfile for customizing model parameters
Container Demo
Use Case
Private LLM Inference on Local Devices: Run large language models locally with no internet requirement—ideal for privacy-critical environments
Lightweight Backend for LLM APIs: Use Ollama to expose models via its local API for fast integration with tools like LangChain, FastAPI, or custom UIs.
Document-Based Q&A Systems: Combine Ollama with a vector database to create offline RAG (Retrieval-Augmented Generation) systems for querying internal documents or manuals.
Rapid Prototyping for Prompt Engineering: Use the Modelfile to fine-tune system prompts, default instructions, and model parameters—great for experimenting with prompt structures or multi-turn workflows.
Multilingual Assistants: Deploy multilingual chatbots using local models that can translate, summarize, or interact in different languages without depending on cloud services.
LLM Evaluation and Benchmarking Easily swap and test different quantized models (e.g., Mistral, LLaMA, DeepSeek) to compare performance, output quality, and memory usage across devices.
Custom Offline Agents: Use Ollama as the reasoning core of intelligent agents that interact with other local tools (e.g., databases, APIs, sensors)—especially powerful when paired with LangChain
Key Features
- Ollama Integration: Lightweight inference engine for quantized models
- Complete AI Framework Stack: PyTorch, TensorFlow, ONNX Runtime, and TensorRT™
- Industrial Vision Support: Accelerated OpenCV and GStreamer pipelines
- Edge AI Capabilities: Support for computer vision, LLMs, and time-series analysis
- Performance Optimized: Tuned specifically for NVIDIA® Jetson Orin™ NX 8GB
- System Prompt & Temperature Control: Fine-tune the parameters using Modelfile.
Host Device Prerequisites
| Item | Specification |
| Compatible Hardware | Advantech devices accelerated by NVIDIA Jetson™ - refer to Compatible Hardware |
| NVIDIA Jetson™ Version | 5.x |
| Host OS | Ubuntu 20.04 |
| Required Software Packages | Refer to Below |
| Software Installation | NVIDIA Jetson™ Software Package Installation |
Required Software Packages on Host Device
These packages are bound with the NVIDIA Jetson™ version of the device. This container supports NVIDIA Jetson™ 5.x.
| Component | Version | Description |
| CUDA® Toolkit | 11.4.315 | GPU computing platform |
| cuDNN | 8.6.0 | Deep Neural Network library |
| TensorRT™ | 8.5.2.2 | Inference optimizer and runtime |
| VPI | 2.2.7 or above | |
| Vulkan | 1.3.204 or above | |
| OpenCV | 4.5.0 | Computer vision library with CUDA® |
Container Environment Overview
Software Components on Container Image
| CUDA® | 11.4.315 | GPU computing platform |
| PyTorch | 2.0.0+nv23.02 | Deep learning framework |
| TensorFlow | 2.12.0 | Machine learning framework |
| ONNX Runtime | 1.16.3 | Cross-platform inference engine |
| GStreamer | 1.16.2 | Multimedia framework |
| Ollama | 0.5.7 | LLM inference engine |
| OpenWebUI | 0.6.5 | Web interface for chat interactions |
Quick Start Guide
For container quick start, including the docker-compose file and more, please refer to README.
Supported AI Capabilities
Language Models Recommendation
| Model Family | Parameters | Quantization | Size | Performance |
| DeepSeek R1 | 1.5 B | Q4_K_M | 1.1 GB | ~15-17 tokens/sec |
| DeepSeek R1 | 7 B | Q4_K_M | 4.7 GB | ~5-7 tokens/sec |
| DeepSeek Coder | 1.3 B | Q4_0 | 776 MB | ~20-25 tokens/sec |
| Llama 3.2 | 1 B | Q8_0 | 1.3 GB | ~17-20 tokens/sec |
| Llama 3.2 Instruct | 1 B | Q4_0 | ~0.8 GB | ~17-20 tokens/sec |
| Llama 3.2 | 3 B | Q4_K_M | 2 GB | ~10-12 tokens/sec |
| Llama 2 | 7 B | Q4_0 | 3.8 GB | ~5-7 tokens/sec |
| Tinyllama | 1.1 B | Q4_0 | 637 MB | ~22-27 tokens/sec |
| Qwen 2.5 | 0.5 B | Q4_K_M | 398 MB | ~25-30 tokens/sec |
| Qwen 2.5 | 1.5 B | Q4_K_M | 986 MB | ~15-17 tokens/sec |
| Qwen 2.5 Coder | 0.5 B | Q8_0 | 531 MB | ~25-30 tokens/sec |
| Qwen 2.5 Coder | 1.5 B | Q4_K_M | 986 MB | ~15-17 tokens/sec |
| Qwen | 0.5 B | Q4_0 | 395 MB | ~25-30 tokens/sec |
| Qwen | 1.8 B | Q4_0 | 1.1 GB | ~15-20 tokens/sec |
| Gemma 2 | 2 B | Q4_0 | 1.6 GB | ~10-12 tokens/sec |
| Mistral | 7 B | Q4_0 | 4.1 GB | ~5-7 tokens/sec |
DeepSeek R1 1.5B Optimization Recommendations:*
- Use INT4-8 (Q4, Q8) quantized models for faster inference
- Best performance with TensorRT™ engine conversion
- Use Jetson™ clocks & higher power modes, if possible
- Run with Jetson™ clocks enabled
- Avoid loading the model from slow storage like SD/eMMC.
- Ensure model is fully loaded into GPU
- Use SWAP/ZRAM in case the model's memory requirements are higher
Hardware Acceleration Support
| Accelerator | Support Level | Compatible Libraries | Notes |
| CUDA® | Full | PyTorch, TensorFlow, OpenCV, ONNX Runtime | Primary acceleration method |
| TensorRT™ | Full | ONNX, TensorFlow, PyTorch (via export) | Recommended for inference optimization |
| cuDNN | Full | PyTorch, TensorFlow | Accelerates deep learning primitives |
| NVDEC | Full | GStreamer, FFmpeg | Hardware video decoding |
| NVENC | Full | GStreamer, FFmpeg | Hardware video encoding |
| DLA | Partial | TensorRT™ | Requires specific model optimization |
Copyright © Advantech Corporation. All rights reserved.
