Catalog
Overview
About Advantech Container Catalog (ACC)
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, it simplifies the challenges often faced with software and hardware compatibility, especially in GPU/NPU-accelerated environments.
Key benefits of the Container Catalog include:
Feature / Benefit Description
Accelerated Edge AI Development Ready-to-use containerized solutions for fast prototyping and deployment
Hardware Compatibility Solved Eliminates embedded hardware and AI software package incompatibility
GPU/NPU Access Ready Supports passthrough for efficient hardware acceleration
Model Conversion & Optimization Built-in AI model quantization and format conversion support
Optimized for CV & LLM Applications Pre-optimized containers for computer vision and large language models
Open Ecosystem 3rd-party developers can integrate new apps to expand the platform
Container Overview
LLM Langchain AI Agent on NVIDIA Jetson™ provides a modular, middleware-powered AI chat solution built for NVIDIA Jetson™ Systems. This stack uses Ollama with LLAMA 3.2 1b Model to serve LLMs, a FastAPI-based LangChain service for middleware logic, and OpenWebUI as the user interface.
This architecture enables tool-augmented reasoning, multi-turn memory, and custom LLM workflows using LangChain Agents.
User Benefits
  • Plug-and-play LLM Container on Edge: supported by variety of Advantech AI-powered hardwares & Containerized environment with GPU passthrough optimized for LLM /Agentic AI applications.
  • Reduce Model Compilation Effort: Standarized model conversion and quantization workflow for users on NVIDIA Jetson™ platforms.
  • Flexible Harware Options: Select AI-powered hardware from Advantech’s verified list to best match your Edge AI application requirements—fully supported and optimized for this container.
Container Demo
Key Features
Feature Content
LLAMA 3.2 1b Inference Efficient on-device LLM deployment via Ollama, optimized for edge environments with minimal memory usage and high-performance inference
Integrated OpenWebUI Clean, user-friendly frontend for interacting with LLMs via chat interface
Custom Model Creation Build or fine-tune your own variants with ollama create
REST API Access Interact with models via a simple local HTTP API
Flexible Parameters Tune inference with temperature, top_k, repeat_penalty, etc
Modelfile Customization Define model behavior and parameters using a Docker-like file
Prompt Templates Automatically format conversations using common structures like chatml or llama
LangChain Agent Integration Enables tool-augmented reasoning, structured prompt handling, and advanced control flow logic for enhanced interactions
LangChain Memory Support Multi-turn chat via ConversationBufferMemory for contextual understanding
FastAPI Middleware Lightweight interface between OpenWebUI and LangChain
Complete AI Framework Stack PyTorch, TensorFlow, ONNX Runtime
Industrial Vision Support Accelerated OpenCVpipelines
Edge AI Capabilities Support for computer vision, LLMs, and time-series analysis
Performance Optimized Tuned specifically for Advantech EPC-R7300 and more devices
Host Device Prerequisites
Item Specification
Compatible Hardware Advantech devices powered by NVIDIA Jetson™ - refer to Compatible hardware
NVIDIA Jetson™ Version 5. x
Host OS Ubuntu 20.04
Required Software packages *refer to below
Software Installation NVIDIA Jetson™ Software Package Installation
Hardware Specifications
Component Specification
Target Hardware NVIDIA Jetson™
GPU NVIDIA Ampere architecture with 1024 CUDA® cores
DLA Cores 1 (Deep Learning Accelerator)
Memory 4/8/16 GB shared GPU/CPU memory
NVIDIA Jetson™ Version 5.x
Container Environment Overview
Architecture
User → OpenWebUI → FastAPI (LangChain Agent) → Ollama Inference
Software Components on Container Image
Component Version Description
NVIDIA CUDA® Toolkit 11.4.315 GPU computing platform
cuDNN 8.6.0 Deep Neural Network library
TensorRT™ 8.5.2.2 Inference optimizer and runtime
PyTorch 2.0.0+nv23.02 Deep learning framework
TensorFlow 2.12.0+nv23.05 Machine learning framework
ONNX Runtime 1.16.3 Cross-platform inference engine
OpenCV 4.5.0 Computer vision library with NVIDIA CUDA® Toolkit
GStreamer 1.16.2 Multimedia framework
Model Information
Item Description
Model source Ollama Model (llama3.2:1b)
Model architecture llama
Model quantization Q8_0
Ollama command ollama pull llama3.2:1b
Number of Parameters ~1.24 B
Model size ~1.3 GB
Default context size (governed by Ollama in this image) 2048
Language Model Recommendation & Performace Reference
Model Family Versions Memory Requirements Performance Notes
DeepSeek R1 1.5B ~1 GB ~15-17 tokens/sec in Q4_K_M
Llama 3.2 1B ~1 GB ~17-20 tokens/sec in Q8_0
DeepSeek Coder Mini (1.3B), Light (1.5B) 2-3 GB
TinyLlama 1.1B 2 GB
Phi Phi-1.5 (1.3B), Phi-2 (2.7B) 1.5-3 GB
Llama 2 7B (Quantized to 4-bit) 3-4 GB
Mistral 7B (Quantized to 4-bit) 3-4 GB
*The performance benchmarking is run on NVIDIA® Jetson Orin™ NX, NVIDIA Jetson™ 5.1.
Quick Start Guide
For container quick start, including docker-compose file, and more, please refer to Advantech Container Repository
Ollama Integration
This container leverages Ollama as the local inference engine to serve LLMs efficiently on NVIDIA Jetson™ systems. Ollama provides a lightweight and container-friendly API layer for running language models like LLAMA3.2-1b without requiring cloud-based services.
Key Highlights:
  • Local model inference via Ollama API (http://localhost:11434/v1)
  • Supports streaming output for chat-based UIs like OpenWebUI
  • Works with quantized .gguf models optimized for edge hardware
Copyright © Advantech Corporation. All rights reserved.
