Catalog
Overview
This container image, LLM Ollama on NVIDIA Jetson™, bundles a ready-to-use Ollama inference engine with the Meta Llama 3.2 1B model and the OpenWebUI interface for LLM interaction.
Developed for NVIDIA Jetson™, this image offers:
  • On-device LLM (Meta Llama 3.2 1B via Ollama) inference (no internet required post-setup)
  • Open-AI compatible APIs
  • Streaming chat support via OpenWebUI & Ollama
  • Modelfile for customizing model parameters
Container Demo
Use Case
  • Private LLM Inference on Local Devices: Run large language models locally with no internet requirement—ideal for privacy-critical environments
  • Lightweight Backend for LLM APIs: Use Ollama to expose models via its local API for fast integration with tools like LangChain, FastAPI, or custom UIs.
  • Document-Based Q&A Systems: Combine Ollama with a vector database to create offline RAG (Retrieval-Augmented Generation) systems for querying internal documents or manuals.
  • Rapid Prototyping for Prompt Engineering: Use the Modelfile to fine-tune system prompts, default instructions, and model parameters—great for experimenting with prompt structures or multi-turn workflows.
  • Multilingual Assistants: Deploy multilingual chatbots using local models that can translate, summarize, or interact in different languages without depending on cloud services.
  • LLM Evaluation and Benchmarking Easily swap and test different quantized models (e.g., Mistral, LLaMA, DeepSeek) to compare performance, output quality, and memory usage across devices.
  • Custom Offline Agents: Use Ollama as the reasoning core of intelligent agents that interact with other local tools (e.g., databases, APIs, sensors)—especially powerful when paired with LangChain
Key Features
  • Ollama Integration: Lightweight inference engine for quantized models
  • Complete AI Framework Stack: PyTorch, TensorFlow, ONNX Runtime, and TensorRT™
  • Industrial Vision Support: Accelerated OpenCV and GStreamer pipelines
  • Edge AI Capabilities: Support for computer vision, LLMs, and time-series analysis
  • Performance Optimized: Tuned specifically for NVIDIA® Jetson Orin™ NX 8GB
  • System Prompt & Temperature Control: Fine-tune the parameters using Modelfile.
Host Device Prerequisites
Item Specification
Compatible Hardware Advantech devices accelerated by NVIDIA Jetson™—refer to Compatible Hardware
NVIDIA Jetson™ Version 5.x
Host OS Ubuntu 20.04
Required Software Packages Refer to Below
Software Installation NVIDIA Jetson™ Software Package Installation
Required Software Packages on Host Device
These packages are bound with the NVIDIA Jetson™ version of the device. This container supports NVIDIA Jetson™ 5.x.
Component Version Description
CUDA® Toolkit 11.4.315 GPU computing platform
cuDNN 8.6.0 Deep Neural Network library
TensorRT™ 8.5.2.2 Inference optimizer and runtime
VPI 2.2.7 or above
Vulkan 1.3.204 or above
OpenCV 4.5.0 Computer vision library with CUDA®
Container Environment Overview
Software Components on Container Image
CUDA® 11.4.315 GPU computing platform
PyTorch 2.0.0+nv23.02 Deep learning framework
TensorFlow 2.12.0 Machine learning framework
ONNX Runtime 1.16.3 Cross-platform inference engine
GStreamer 1.16.2 Multimedia framework
Ollama 0.5.7 LLM inference engine
OpenWebUI 0.6.5 Web interface for chat interactions
Container Quick Start Guide
For container quick start, including the docker-compose file and more, please refer to README.
Supported AI Capabilities
Vision Models
Model Family Versions Performance (FPS) Quantization Support
YOLO v3/v4/v5 (up to v5.6.0), v6 (up to v6.2), v7 (up to v7.0), v8 (up to v8.0) YOLOv5s: 45-60 @ 640x640, YOLOv8n: 40-55 @ 640x640, YOLOv8s: 30-40 @ 640x640 INT8, FP16, FP32
SSD MobileNetV1/V2 SSD, EfficientDet-D0/D1 MobileNetV2 SSD: 50-65 @ 300x300, EfficientDet-D0: 25-35 @ 512x512 INT8, FP16, FP32
Faster R-CNN ResNet50/ResNet101 backbones ResNet50: 3-5 @ 1024x1024 FP16, FP32
Segmentation DeepLabV3+, UNet DeepLabV3+ (MobileNetV2): 12-20 @ 512x512 INT8, FP16, FP32
Classification ResNet (18/50), MobileNet (V1/V2/V3), EfficientNet (B0-B2) ResNet18: 120-150 @ 224x224, MobileNetV2: 180-210 @ 224x224 INT8, FP16, FP32
Pose Estimation PoseNet, HRNet (up to W18) PoseNet: 15-25 @ 256x256 FP16, FP32
Language Models Recommendation
Model Family Parameters Quantization Size Performance
DeepSeek R1 1.5 B Q4_K_M 1.1 GB ~15-17 tokens/sec
DeepSeek R1 7 B Q4_K_M 4.7 GB ~5-7 tokens/sec
DeepSeek Coder 1.3 B Q4_0 776 MB ~20-25 tokens/sec
Llama 3.2 1 B Q8_0 1.3 GB ~17-20 tokens/sec
Llama 3.2 Instruct 1 B Q4_0 ~0.8 GB ~17-20 tokens/sec
Llama 3.2 3 B Q4_K_M 2 GB ~10-12 tokens/sec
Llama 2 7 B Q4_0 3.8 GB ~5-7 tokens/sec
Tinyllama 1.1 B Q4_0 637 MB ~22-27 tokens/sec
Qwen 2.5 0.5 B Q4_K_M 398 MB ~25-30 tokens/sec
Qwen 2.5 1.5 B Q4_K_M 986 MB ~15-17 tokens/sec
Qwen 2.5 Coder 0.5 B Q8_0 531 MB ~25-30 tokens/sec
Qwen 2.5 Coder 1.5 B Q4_K_M 986 MB ~15-17 tokens/sec
Qwen 0.5 B Q4_0 395 MB ~25-30 tokens/sec
Qwen 1.8 B Q4_0 1.1 GB ~15-20 tokens/sec
Gemma 2 2 B Q4_0 1.6 GB ~10-12 tokens/sec
Mistral 7 B Q4_0 4.1 GB ~5-7 tokens/sec
Meta Llama 3.2 1B Optimizations Recommendations:
  • Use INT4-8 (Q4, Q8) quantized models for faster inference
  • Best performance with TensorRT™ engine conversion
  • Use Jetson™ clocks & higher power modes, if possible
  • Run with Jetson™ clocks enabled
  • Avoid loading the model from slow storage like SD/eMMC.
  • Ensure model is fully loaded into GPU
  • Use SWAP/ZRAM in case the model's memory requirements are higher
Supported AI Model Formats
Format Support Level Compatible Versions Notes
ONNX Full 1.10.0 - 1.16.3 Recommended for cross-framework compatibility
TensorRT™ Full 7.x - 8.5.x Best for performance-critical applications
PyTorch (JIT) Full 1.8.0 - 2.0.0 Native support via TorchScript
TensorFlow SavedModel Full 2.8.0 - 2.12.0 Recommended TF deployment format
TFLite Partial Up to 2.12.0 May have limited hardware acceleration
GGUF Full v3 Format used by Ollama backend
Hardware Acceleration Support
Accelerator Support Level Compatible Libraries Notes
CUDA® Full PyTorch, TensorFlow, OpenCV, ONNX Runtime Primary acceleration method
TensorRT™ Full ONNX, TensorFlow, PyTorch (via export) Recommended for inference optimization
cuDNN Full PyTorch, TensorFlow Accelerates deep learning primitives
NVDEC Full GStreamer, FFmpeg Hardware video decoding
NVENC Full GStreamer, FFmpeg Hardware video encoding
DLA Partial TensorRT™ Requires specific model optimization
Copyright © Advantech Corporation. All rights reserved.
