Catalog
Overview
Neutron NPU Passthrough on NXP i.MX95
Overview
The Neutron-NPU-Passthrough-on-NXP-i.mx95 provides a ready-to-use inference environment for validating ONNX models on the NXP i.MX95 platform with full support for Neutron NPU hardware acceleration.
This container is intended for developers, system integrators, and solution architects who need a fast and reproducible way to evaluate CPU vs NPU inference performance on i.MX95 without dealing with complex dependency resolution, driver alignment, or runtime configuration.
All required runtimes, libraries, and demo assets are pre-configured, enabling immediate execution of AI inference workloads.
Key Features
  • ONNX Runtime on i.MX95
    Pre-integrated ONNX Runtime optimized for NXP i.MX95 architecture.
  • Neutron NPU Acceleration
    Native support for i.MX95 Neutron NPU via ONNX Runtime Execution Provider.
  • Out-of-Box Inference Demo
    Includes a complete image classification example using MobileNetV2.
  • CPU / NPU Comparison
    Simple runtime switch for validating functional correctness and performance.
  • Lightweight & Reproducible
    Focused container design for benchmarking, validation, and PoC workflows.
Hardware Specifications
Component Specification
Target Hardware Advantech AOM-5521
SoC NXP i.MX95
GPU Arm® Mali™ G310
NPU eIQ neutron N3-1034S
Memory 8 GB LPDDR5
Operating System
Environment Operating System
Device Host Yocto 5.2 Walnascar
Container Ubuntu:24.04
Software Components
Component Version Description
ONNX Runtime 1.22.0 from NXP BSP v6.12.20 Inference runtime
Python 3.13 Demo application runtime
NumPy / Pillow Latest Image preprocessing
Included Models & Assets
Image Classification Model
Model Format Note
MobileNetV2 ONNX Lightweight CNN for inference validation
Demo Assets
File Description
grace_hopper.bmp Sample RGB image
labels.txt ImageNet classification labels
Hardware Acceleration Support
Accelerator Support Level Notes
NPU (Neutron) INT8 (primary) Best performance-per-watt on i.MX95
CPU FP32 Reference & fallback execution
Precision Support
Precision Supported On Notes
INT8 NPU / CPU Recommended for deployment
FP32 CPU Debug & reference
Quick Start Guide
Prerequisites
  • Please ensure docker & docker compose are available and accessible on device host OS
  • Since default eMMC boot provides only 16 GB storage which is in-sufficient to run/build the container image, it is required to boot the Host OS using a 32 GB (minimum) SD card.
For container quick start, including the docker-compose file and more, please refer to Advantech Container Github Repository
Best Practices & Known Limitations
  • Minimum storage Storage required for running Docker containers is 32 GB
  • NPU passthrough Neutron EP error sometimes, reboot the development board may solve this problem.
Neutron: NEUTRON_IOCTL_BUFFER_CREATE failed!: Cannot allocate memory
Copyright © 2026 Advantech Corporation. All rights reserved.
