Catalog
Overview
OpenClaw on Intel iGPU via OpenVINO
Short summary: Run OpenClaw with a local Qwen3-8B LLM accelerated by Intel iGPU via OpenVINO GenAI in a Docker container for Windows with WSL2.
About Advantech Container Catalog (ACC)
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, it simplifies the challenges often faced with software and hardware compatibility, especially in GPU/NPU-accelerated environments.
Feature / Benefit Description
Accelerated Edge AI Development Ready-to-use containerized solutions for faster prototyping and deployment
Hardware Compatible Reduces hardware and package incompatibility issues
GPU/NPU Access Ready Supports passthrough for efficient hardware acceleration
Model Conversion & Optimization Built-in model conversion and quantization recommendations
Optimized for CV & LLM Applications Optimized stacks for vision and language workloads
Container Overview
This container packages OpenClaw with a local LLM inference stack that runs on Intel iGPU through OpenVINO GenAI. It is designed for Windows hosts using WSL2 and automates Docker, Node.js, OpenClaw, and model configuration to deliver a browser-based OpenClaw UI backed by Qwen3-8B-int4-ov.
Demo
Use Case
  • Local LLM service for edge AI applications on Intel iGPU
  • Offline inference and on-premises chatbot deployment
  • Proof-of-concept for OpenVINO-powered LLM acceleration in Windows/WSL2 environments
Key Features
  • Containerized OpenClaw with support for Intel iGPU acceleration via OpenVINO GenAI
  • Automatic Windows/WSL2 setup and Docker-based deployment
  • Local LLM inference using Qwen3-8B-int4-ov with ollama_openvino
Host Device Prerequisites
Item Specification
Compatible Hardware Intel Core Ultra CPU with Intel Graphics iGPU
Platform Version Windows 10 IoT Enterprise LTSC 21H2 or Windows 11 (22H2+)
Host OS Windows with WSL2 + Ubuntu 24.04
Required Packages Docker Engine, Node.js 22, npm, OpenClaw, OpenVINO GenAI, ollama_openvino
Software Installation Guide README.md in repository
Required Software Packages on Host Device
Component Version Description
Windows WSL2 Ubuntu 24.04 Linux environment for container runtime
Docker Engine Latest supported Container runtime without Docker Desktop
Node.js 22 Required by OpenClaw and setup scripts
OpenVINO GenAI 2026.1 Intel iGPU model inference backend
Intel GPU driver 32.0.101.8735+ Required for OpenVINO iGPU access
Container Environment Overview
Software Components in the Image
OpenClaw Latest stable Web-based gateway for local LLM interaction
ollama_openvino Built from source OpenVINO provider for ollama-style model serving
OpenVINO GenAI 2026.1 Intel iGPU inference engine
Qwen3-8B-int4-ov 8B quantized model Local LLM model running on Intel iGPU
Container Quick Start Guide
For container quick start and deployment details, see the step-by-step guide at: Advantech Containers Github
Supported AI Capabilities
Language Models
Model Family Suggested Sizes Memory Req.
Qwen3 8B int4 Medium
Optimization tips: Use the provided OpenVINO model build and Intel iGPU driver version 32.0.101.8735+ for best performance.
Supported AI Model Formats
Format Support Level Notes
OpenVINO Full Native Intel iGPU acceleration
ONNX Partial Possible via OpenVINO conversion workflows
Hardware Acceleration Support
Accelerator Support Level Compatible Libraries Notes
Intel iGPU Full OpenVINO GenAI, ollama_openvino Requires /dev/dxg passthrough from Windows WSL2
Troubleshooting & Notes
  • Common issues: Docker permission denied in WSL2, Intel iGPU not detected, WSL version too old, OpenClaw UI unreachable from Windows browser.
  • Known limitations: Requires WSL2 Ubuntu 24.04 and compatible Intel GPU driver; UI access may require Windows port proxy configuration on some systems.
Note: This page is based on the README.md for the OpenClaw OpenVINO Intel iGPU container.
Copyright © Advantech Corporation. All rights reserved.
