Catalog
Overview
YOLO Vision Applications on AMD Ryzen™ AI NPU
Short summary: Real-time YOLO-based computer vision applications (object detection, classification, and segmentation) optimized for AMD Ryzen AI NPU hardware acceleration.
About Advantech Container Catalog (ACC)
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, it simplifies the challenges often faced with software and hardware compatibility, especially in GPU/NPU-accelerated environments.
Feature / Benefit Description
Accelerated Edge AI Development Ready-to-use containerized solutions for faster prototyping and deployment
Hardware Compatible Reduces hardware and package incompatibility issues
GPU/NPU Access Ready Supports passthrough for efficient hardware acceleration
Model Conversion & Optimization Built-in model conversion and quantization recommendations
Optimized for CV & LLM Applications Optimized stacks for vision and language workloads
Container Overview
This container provides a complete YOLO vision application environment optimized for AMD Ryzen AI NPU acceleration. It includes pre-configured tools for running YOLO11 models in multiple tasks (object detection, classification, and segmentation) with real-time performance on embedded AMD Ryzen systems. The container simplifies deployment by bundling the Ryzen AI runtime, necessary dependencies, and example applications.
Demo
Segmentation:
Detection:
Use Case
  • Real-time object detection on embedded systems
  • Video analysis and monitoring applications
  • Instance segmentation for autonomous systems
  • Image classification at the edge
  • Performance comparison between NPU and CPU acceleration
  • Model conversion and optimization for edge deployment
Key Features
  • NPU acceleration for real-time YOLO inference
  • Support for YOLO11 detection, classification, and segmentation models
  • Easy model format conversion (PyTorch to ONNX)
  • Dual execution modes: NPU-accelerated and CPU-only for comparison
  • Live webcam and video file processing
  • Built-in performance diagnostics and benchmarking
  • Headless mode for server deployments
  • Integrated virtual environment with pre-installed dependencies
Host Device Prerequisites
Item Specification
Compatible Hardware AMD Ryzen AI NPU-enabled systems (e.g., AIMB-RN)
Platform Version Ryzen AI NPU Runtime 1.6+
Host OS Linux (Ubuntu 22.04 LTS recommended)
Required Packages Docker, XRT (Xilinx Runtime), XDNA driver
Required Software Packages on Host Device
Component Version Description
XDNA Driver Latest AMD Ryzen AI NPU kernel driver and firmware
XRT (Xilinx Runtime) Latest Runtime for NPU execution and device management
Docker 20.10+ Container runtime platform
Docker Compose 2.0+ Multi-container orchestration
Boost Libraries 1.71+ Required dependency for NPU runtime
Container Environment Overview
Software Components in the Image
Ryzen AI Runtime 1.6+ AMD Ryzen AI NPU execution engine
Python 3.10+ Programming language runtime
ONNX Runtime Latest Cross-platform inference engine
OpenCV Latest Computer vision library for image processing
YOLO11 Latest Object detection/segmentation models
PyTorch Latest Deep learning framework
GStreamer Latest Multimedia framework for video processing
Container Quick Start Guide
For installation, setup, build scripts, and detailed usage instructions, please refer to the Vision-Applications-on-AMD-Ryzen README in the repository.
Supported AI Capabilities
Vision Models
Model Family Supported Versions Notes
YOLO YOLO11 (nano, small, medium, large) Object detection and segmentation
YOLO Classification YOLO11-cls Image classification tasks
YOLO Segmentation YOLO11-seg Instance segmentation
Supported Model Formats
Format Support Level Notes
ONNX Full Primary format for NPU inference
PyTorch Full Native YOLO format, export to ONNX recommended
TensorFlow SavedModel Supported Via conversion utilities
Hardware Acceleration Support
Accelerator Support Level Compatible Libraries Notes
AMD Ryzen AI NPU Full Ryzen AI Runtime, ONNX Runtime Primary acceleration target
CPU Fallback Full OpenCV, PyTorch, ONNX Runtime For comparison and compatibility
Troubleshooting & Notes
  • NPU test falls back to CPU execution:
    • Check that required Boost runtime libraries are installed
    • Ensure /opt/xilinx/xrt exists and is mounted into the container
  • General considerations:
    • The Docker container reuses host-installed XRT and firmware
    • Reboot the host after any NPU driver or firmware update
    • For detailed setup and execution instructions, refer to the README in the repository
Copyright © Advantech Corporation. All rights reserved.
