Catalog
Containers
Overview
LLM Langchain on NVIDIA Jetson™
About Advantech Container Catalog
Advantech Container Catalog is a comprehensive collection of ready-to-use, containerized software packages designed to accelerate the development and deployment of Edge AI applications. By offering pre-integrated solutions optimized for embedded hardware, it simplifies the challenges often faced with software and hardware compatibility, especially in GPU/NPU-accelerated environments.
Key benefits of the Container Catalog include:
Feature / Benefit Description
Accelerated Edge AI Development Ready-to-use containerized solutions for fast prototyping and deployment
GPU/NPU Access Ready Supports passthrough for efficient hardware acceleration
Model Conversion & Optimization Built-in AI model quantization and format conversion support
Optimized for CV & LLM Applications Pre-optimized containers for computer vision and large language models
Scalable Device Management Supports large-scale IoT deployments via EdgeSync, Kubernetes, etc.
Container Overview
LLM Langchain on NVIDIA Jetson™ Edge AI Container Image provides a modular, middleware-powered AI chat solution built for NVIDIA Jetson™ systems. This stack uses Ollama with Meta Llama 3.2 1B Model to serve model inference, a FastAPI-based Langchain service for middleware logic, and OpenWebUI as the user interface. It could be used to enable tool-augmented reasoning, conversational memory, custom LLM workflows and build Agents. It also offers full hardware acceleration
Key Features
Feature Description
Integrated OpenWebUI Clean, user-friendly frontend for LLM chat interface
Meta Llama 3.2 1B Inference Efficient on-device LLM via Ollama; minimal memory, high performance
Model Customization Create or fine-tune models using ollama create
REST API Access Simple local HTTP API for model interaction
Flexible Parameters Adjust inference with temperature, top_k, repeat_penalty, etc.
Modelfile Customization Configure model behavior with Docker-like Modelfile syntax
Prompt Templates Supports formats like chatml, llama, and more
LangChain Integration Multi-turn memory with ConversationChain support
FastAPI Middleware Lightweight interface between OpenWebUI and LangChain
Offline Capability Fully offline after container image setup; no internet required
Container Demo
Inference Flow
User → OpenWebUI → FastAPI → LangChain → Ollama → Meta Llama 3.2 1B
Host Device Prerequisites
Item Specification
Compatible Hardware Advantech devices accelerated by NVIDIA Jetson™ - refer to Compatible hardware
NVIDIA Jetson™ Version 5. x
Host OS Ubuntu 20.04
Required Software packages *refer to below
Software Installation Jetson™ Software Package Installation
Required Software Packages on Host Device
These packages are bound with NVIDIA Jetson™ version of the device. This container supports version 5.x.
Component Version Description
CUDA® 11.4.315 GPU computing platform
cuDNN 8.6.0.166 Deep Neural Network library
NVIDIA® TensorRT™ 8.5.2.2 Inference optimizer and runtime
VPI 2.2.7 or above
Vulkan 1.3.204 or above
OpenCV 4.5.4 with CUDA®: NO
Container Environment Overview
Software Components on Container Image
The following software components are available in the base image of GPU Passthrough on NVIDIA Jetson™:
cuDNN 8.6.0 Deep Neural Network library
TensorRT 8.5.2.2 Inference optimizer and runtime
PyTorch 2.0.0+nv23.02 Deep learning framework
TensorFlow 2.12.0+nv23.05 Machine learning framework
ONNX Runtime 1.16.3 Cross-platform inference engine
OpenCV 4.5.0 Computer vision library with CUDA®
GStreamer 1.16.2 Multimedia framework
The following software components/packages are provided further inside this container image & host (via build script), optimized for LLM application:
Ollama 0.5.7 LLM Backend, installed on Host for better performance
LangChain 0.2.17 Installed via PIP, framework to build LLM applications
FastAPI 0.115.12 Installed via PIP, develop OpenAI compatible APIs for serving LangChain
OpenWebUI Latest Provided via seprate OpenWebUI container for UI
Meta Llama 3.2 1B N/A Pulled on Host via build script
Ollama As LLM Backend
This container leverages Ollama as the local inference engine to serve LLMs efficiently on NVIDIA Jetson™ systems. Ollama provides a lightweight and container-friendly API layer for running language models without requiring cloud-based services.
Key Highlights:
  • Local model inference via Ollama API (http://localhost:11434/v1)
  • Supports streaming output for chat-based UIs like OpenWebUI
  • Works with quantized .gguf models optimized for edge hardware
  • Run huggingface models by converting them to .gguf format and quantize for smaller size (refer to quantization-readme.md)
  • Model behavior can be customized via Modelfile parameters (e.g., temperature, context size, repeat_penalty, etc.)
  • Simple CLI (ollama run, ollama pull) for easy local model management and testing
  • Supports model composition via system and user prompts for advanced prompt engineering
  • Offline-first: no internet connection required after initial model pull
Model Information
This image uses Meta Llama 3.2 1B for inferencing, here are the details about the model used:
Item Description
Model source Ollama Model (llama3.2:1b)
Model architecture llama
Model quantization Q8_0
Ollama command ollama pull llama3.2:1b
Number of Parameters ~1.24 B
Model size ~1.3 GB
Default context size (governed by Ollama in this image) 2048
Hardware Specifications
Component Specification
Target Hardware NVIDIA Jetson™
GPU NVIDIA Ampere architecture with 1024 CUDA® cores
DLA Cores 1 (Deep Learning Accelerator)
Memory 4/8/16 GB shared GPU/CPU memory
NVIDIA Jetson™ Version 5.x
Quick Start Guide
For container quick start, including docker-compose file, and more, please refer to Advantech EdgeSync Container Repository
Possible Usecases
Leverage the container image to build interesting use cases like:
Use Case Description
Predictive Maintenance Chatbots Integrate with edge telemetry or logs to summarize anomalies, explain error codes, or recommend corrective actions using historical context
Compliance and Audit Q&A Run offline LLMs trained on local policy or compliance data to assist with audits or generate summaries — keeping data on-prem
Safety Manual Conversational Agents Deploy LLMs to provide instant answers from on-site safety manuals or procedures, reducing downtime and improving adherence
Technician Support Bots Field engineers can interact with bots to troubleshoot equipment using repair logs, parts catalogs, and service manuals
Smart Edge Controllers LLMs translate human intent (e.g., “reduce line 2 speed by 10%”) into control commands for industrial PLCs or middleware
Conversational Retrieval (RAG) Integrate with vector databases (e.g., FAISS, ChromaDB) to retrieve context from local docs for Q&A over your custom data
Tool-Enabled Agents Intelligent agents can use tools like calculators, APIs, or search — with LangChain managing the logic and LLM interface
Factory Incident Reporting Ingest logs or voice input → extract incident type → summarize → trigger automated alerts or next steps
Copyright © 2025 Advantech Corporation. All rights reserved.
